Subject: Poser 5 thumbnails?
Zarabanda opened this issue on Apr 23, 2004 ยท 6 posts
Zarabanda posted Fri, 23 April 2004 at 2:04 AM
I've created both .rsr and .png thumbnails for a mat pose and both work in poser 4. The pose was created with mat pose edit and works fine. But whatever I do the thumbnail doesn't show up in poser 4, its just blank with a transparent circle. so if the thumbnail works in poser 4, can anyone tell me why its not working i poser 5? the .png was created in photoshop 7 and the .rsr was created in p3do explorer.
jasmina posted Fri, 23 April 2004 at 5:04 AM
I remember that thumbnail format of png must be a indexed color with 256 color. Convert it with Photoshop before saving.
TrekkieGrrrl posted Fri, 23 April 2004 at 5:27 AM
It's probably the bug in P3d0Explorer, in the latest version the rsr2png is wrong, it reverses the alphachannel. Download the PLUGIN called rsr2png and put that in P3DO instead, and I think it will make them work :o)
Jackson posted Fri, 23 April 2004 at 10:58 AM
In Photoshop, make sure the image you want isn't the background. If it is, select it and make it a layer then delete the background layer. You should only have one layer now: Layer 1. Also check the Channels palette and make sure there's an alpha channel. Save it that way and it should appear in Poser.
Zarabanda posted Fri, 23 April 2004 at 1:34 PM
jackson, your action saved me! you da man, Thanks to everyone!
Jackson posted Fri, 23 April 2004 at 1:43 PM
You're welcome; glad to hear it worked ;)
