Subject: Poser Newbie needs help!!!
Steelrat opened this issue on Oct 03, 2000 ยท 3 posts
Steelrat posted Tue, 03 October 2000 at 7:12 AM
Hi folks! I'm very new to all this stuff and first let me say that you all do a great job on your works. My problem now is that I have the german version of Poser 4 and it seems that the most of your files doesn't work with this version, because of the language. My Poser can't find the needed files for using your characters and other stuff. Can you help me? And if there are any germans around here, I would appreciate it if you tell me in german. Thanx in advance and keep up your fantastic work.
ninhalo5 posted Tue, 03 October 2000 at 10:03 AM
sorry i dont speak any german but give this a try if the problem lies in with textures cant find this and that texture possibly cause of big file names click on the name of the file it is looking for and right click your mouse hit copy then find the file it most likely resembles and the highlight that file and right click again and rename it then ok it it should take and if the problem lies in with obj files remember that poser is very sensitave say for instance you get an error that says cannot open Geometries/Characters/WhatsUpDoc.obj and then you get an out of memory error you'll have to go through your folders and make sure everything is spelled excatly the same that it is looking for even with capitol letters try opening the cr2 file with your word pad and it will tell you excatly what your looking for just make folders and files names to match hope this helps jeff
thgeisel posted Tue, 03 October 2000 at 12:09 PM
Hi, ich bin Deutscher und habe auch die deutsche Poserversion.Ich hatte bisher diese probs nicht.man muss allerdings hfig die dateinen manuell in die richtigen Unterverzeichnisse von Poser kopieren.Wenn weiterhin Probs auftreten: thgeisel@crw.net
