Forum: Bryce
Subject: Newbie problem - creating a hole in the ground - help please
brodiss opened this issue on Apr 25, 2004 ยท 3 posts
brodiss posted Sun, 25 April 2004 at 8:10 AM
i've successfully used positive and negative attributes to make holes before but am having troubles with an image i'm cuurently working on.
i've imported an object which i want to use as a cavity - but i've been unable to get it to work. the land plane persists in obscuring it no matter what i tell it or the object - even when the language becomes strong. :/
any suggestions/ advice would be more than welcome. thanks.
pogmahone posted Sun, 25 April 2004 at 8:37 AM
Hi brodiss - once you've imported your OBJ, select it, click on the E (Edit) and put a dot on the button that says something like Solid when Boolean. That'll do it!
brodiss posted Sun, 25 April 2004 at 8:40 AM
thanks pogmahone. another bryce mystery solved. :) your help is much appreciated
