Forum: Carrara
Subject: Texture Map Export Problems
sailor_ed opened this issue on Apr 25, 2004 ยท 4 posts
sailor_ed posted Sun, 25 April 2004 at 8:35 AM
I am trying to export some models from C3 in 3ds or obj format. When exporting there is a check box for exporting procedural textures as files (jpg, bmp etc). It also has a space for resolution. No matter what I put in the resolution box (ie 1024X1024) all I get are files 128X128 pixels. Anyone have experience with this?
Thanks in advance
TPC* Ed
*The Perpetually Confused
Pete_Exxtreme posted Sun, 25 April 2004 at 10:06 AM
Hi Ed, It works fine for me in 1024 in jpg at least ... did u patched to the latest 3.03 version ????? Pete
glought posted Sun, 25 April 2004 at 1:48 PM
I agree with Exxtreme Ed. You should be getting larger file sizes when you change up. It might be better to save a copy of your existing Carrara folder then un-install and re-install it again then apply the patch and test the export. If it works you can then move your old custom files and shaders back. I had to do this a few times to clear up a few un-expected errors when rendering. Hope this helps. George
sailor_ed posted Sun, 25 April 2004 at 8:00 PM
I am patched to 3.03 so I'll try the re-install and re-examine my technique. If it works for you I should be able figure it out. Thanks both for the info. Ed
