Gregpktm opened this issue on Apr 30, 2004 ยท 10 posts
Gregpktm posted Fri, 30 April 2004 at 2:20 PM
1.How can I rotate a layer by taking as center a specific poitn and not the layer's center? 2.Is there any Radial Array command in Photoshop?
cryptojoe posted Fri, 30 April 2004 at 4:26 PM
Yank My Doodle, It's a
Dandy!
Dandy!
cryptojoe posted Fri, 30 April 2004 at 4:27 PM
Dandy!
cryptojoe posted Fri, 30 April 2004 at 4:28 PM
Look real careful there at the cursor. See the little circle with cross-hairs? This is what we move.
Dandy!
cryptojoe posted Fri, 30 April 2004 at 4:29 PM
Dandy!
cryptojoe posted Fri, 30 April 2004 at 4:30 PM
Dandy!
cryptojoe posted Fri, 30 April 2004 at 4:32 PM
Anyway, you need to first select this tool I'm talking about before you do the select all, edit, rotate thingie...
Dandy!
dreamer101 posted Fri, 30 April 2004 at 4:57 PM
Select > All is not necessary. Edit > Transform > Rotate. It will put a bounding box around non tranparent part of layer only. You can then drag the center point to any place and rotate around that point. It also doesn't matter which tool you have selected at the time.
Gregpktm posted Sun, 02 May 2004 at 3:01 PM
OK! Thanks for the help.
