Forum: Bryce
Subject: Error Message
Kafra opened this issue on Oct 05, 2000 ยท 3 posts
Kafra posted Thu, 05 October 2000 at 7:01 PM
HELP!!! I have been working on a scene for about two weeks...... When I tried to open it today I go the message "An Unexpected Error Occurred (object not found)" I can't open the file.... HELP!!!
inyerface posted Fri, 06 October 2000 at 12:01 PM
I've had success opening those files from B3D since I got 4.1! I use a Mac. Hopefully this helps.
devilboy posted Sun, 08 October 2000 at 8:59 AM
yeah, i'm using bryce 4.0, and i've had that happen to me too. it acts like it's loading the scene, gets to the point where the wireframes should pop up, and then it reverts to the default scene and gives that damned error message. the only solution i've found is to save big projects twice, with different filenames, so you have a backup copy. otherwise you just grit your teeth, clench your fists, and try like hell not to punch the screen as you start over from the beginning.
