Forum: Poser Technical
Subject: problem about bend
smalll opened this issue on May 02, 2004 ยท 7 posts
smalll posted Sun, 02 May 2004 at 2:19 AM
Hi, everyone. I'm korean. (Republic of Korea) So, my english is poor. I'm sorry. I'm just beginner of poser. I make box arm. I want to bend it smooth. But it is not. How can I bend it smoothly? You can download my file. http://www.smalll.x-y.net/etc/Runtime.zip Preview image is here. http://www.smalll.x-y.net/etc/SNAG-0000.jpg Please help me...
SAMS3D posted Sun, 02 May 2004 at 5:14 AM
Try turning the bend off on all parts. Sharen
smalll posted Sun, 02 May 2004 at 6:52 AM
First, Thank for your reply. I tried to bend off. But, the result of bending off is not smooth. Please tell me more..
mateo_sancarlos posted Sun, 02 May 2004 at 1:51 PM
Image 02 is smooth; it has bending applied. Create labelled drawings of:
  1. desired image
  2. image that is wrong
lesbentley posted Mon, 03 May 2004 at 5:25 AM
I think the problem here might be the mesh its self, and perhaps also in the UV mapping. As I understsnd it (and I don't understand it very well) an object can only bend along seams in the mesh the more seams the smoother the bending. See the comparison between your figure and a Poser box prop when a magnet is applied, the boxprop has more places where it can bend.
I think whether the vertices are split or welded may also have an effect on how the object bends, I think welded vertices will will give a smother bend.
I an no expert on any of this, but hopefully someone with more knowledge on this subject will either confirm or deny what I have said above.
lesbentley posted Mon, 03 May 2004 at 6:03 AM
The way an object bends is also controled be the Joint Paramiters. The graphic above showes a figure that was made out of two Poser box props. It demonstrates how using the Jount Editor can change the way the figure bends.
smalll posted Mon, 03 May 2004 at 5:11 PM
Thanks to lesbentley! It is my a purpose. You give me great help. It'll come in pretty handy to me. Thank you very much.
