Gald opened this issue on May 02, 2004 ยท 5 posts
Gald posted Sun, 02 May 2004 at 2:54 PM
SamTherapy posted Sun, 02 May 2004 at 3:01 PM
You need to uncheck "smooth polygons" for that figure. It's a known problem which affects some objects, not others. I haven't yet encountered it but it's reckoned to be a commonplace happening.
Gald posted Sun, 02 May 2004 at 3:23 PM
ok thanks for your help. // Fredrik
xantor posted Sun, 02 May 2004 at 7:12 PM
In the render options switch off smooth polygons and only use it if you need to. Its the same with use displacement maps, if you arent using displacement then that option can be turned off too.
Gald posted Mon, 03 May 2004 at 12:42 AM
thank you xantor for your answer, yes I was needed to switch off smooth polygons in render options to get the bow to look as it should.
