Subject: Is there a way?????
1010 opened this issue on May 06, 2004 ยท 9 posts
1010 posted Thu, 06 May 2004 at 5:48 AM
The person I purchased an item from told me to ask my question here. She no longer uses poser. The files are for the pose library and face library. I use Poser5 and it has no face room and dosen't recognize her files. The files are such: rsr fc2 pz2 Is there a way to convert these? Or should I ask for a refund. I'm relatively new to Poser. Thanks for your help.............
http://creationsbydawn.net
neilp posted Thu, 06 May 2004 at 6:10 AM
No problem. In windows explorer locate you Poser 5RuntimeLibraries directory. You will notice a directory called Face and Directory called Pose. Please the .FC2 and correcspoding .RSR files in the Face Directory and Please and .PZ2 and coressponding .RSR files in the pose directory. Load poser 5 and look in the Expressions (Face) and pose folders and you should see the files. Welcome to Poser 5. You'll be as addited to it as the rest of us before you know it.
1010 posted Thu, 06 May 2004 at 6:42 AM
Oh yes, I am way to addicted and my checkbook knows it too!!! lol Ok, I see that when I open poser that the files are in the expression library but when I try to use them I get a sign: Some information stored in this library entry does not pertain to figures of this type. They won't load. So poser isn't recognizing them, any suggestions? Thanks..............
las_61 posted Thu, 06 May 2004 at 7:16 AM
It sounds like you're trying to use them on the wrong figure.
neilp posted Thu, 06 May 2004 at 7:17 AM
You are trying to apply a face morph (Face) to a different model than the face morph was created for. For example applying a victoria 2 Face morph to Michael 2 would generate this error message. If you have a look inside the FC2 file with wordpad or notepad you will see listed the geometry file that the face morph pertains to. From there you can workout which model it will work with. I hope this makes sense.
1010 posted Thu, 06 May 2004 at 7:55 AM
Yes it makes sense, I looked again and it's for Stephanie and that's the figure I used, with and without the morphs, it just won't work. I have S3 could it be for an earlier S model? Just looking for answers. You guys are great!
stephaniebt posted Thu, 06 May 2004 at 8:14 AM
Dawnie, I think that's the problem. There is a Stephanie, but it's not the same as S3. :)
1010 posted Thu, 06 May 2004 at 8:27 AM
Hi Steph, Oh my, looks like it will never work then........:( Live and learn the hard way is my motto! Thanks everyone.
hauksdottir posted Sat, 08 May 2004 at 3:31 AM
You should be able to get the orignal Stephanie at DAZ, and probably for a reduced price. I really wish that they would rename a figure when they make such fundamental changes to it... otherwise there is confusion 2-3 years down the road. Carolly
