akura_ opened this issue on May 06, 2004 ยท 5 posts
akura_ posted Thu, 06 May 2004 at 3:10 PM
how do you change the background color
neilp posted Thu, 06 May 2004 at 3:32 PM
I assume that you have poser 5 and you have just applied the service release 4.1. If this is the case then follow these steps. Run Poser. Go to the material room and select the background colour. You will notice that there are a few rogue nodes with the name background. Delete any that are not connected. Go back to the pose room and set poser prefs to launch from prefered state. Note. You will need to repeast this process for any projects you have saved since service pack 4.1.
Nevermore posted Thu, 06 May 2004 at 4:50 PM
Thanks for that it's resolved a gremlin that has been annoying me for a while. :o)
akura_ posted Fri, 07 May 2004 at 6:24 AM
thanks its only locked I guess for this one file I had.
hauksdottir posted Sat, 08 May 2004 at 1:06 AM
The instructions are also in the readme which comes with this SR... in case you ever need to reinstall.
