Forum: Bryce
Subject: how to select just one eyebrow
Wishmaster opened this issue on Oct 08, 2000 ยท 4 posts
Wishmaster posted Sun, 08 October 2000 at 10:18 PM
i extracted the P4 males head in bryce cause i wanted to use the eyebrows. is there a way i can select just one brow? cause whne i click on one brow it hilites the other. thanx very much
Gary V. posted Mon, 09 October 2000 at 11:21 PM
Export it to UVMapper and make each eyebrow separate group. When you re import them to bryce they will be individually selectable.
Wishmaster posted Tue, 10 October 2000 at 1:01 AM
thanx Gary but howdo i do that i rellayt dunnoalot bout poser
Gary V. posted Tue, 10 October 2000 at 1:20 AM
In re-reading your first post, it looks like all you want are the eyebrows and nothing else. If so, when you export from poser, it gives you the option to add/remove parts of the figure you're exporting. Uncheck everything but the eyebrows. I don't have Poser available at the moment, but I think each eyebrow is a separate mesh. Just pic the one you want and finish the export as an .obj Then, import into Bryce. Does that do it? Gary
