Subject: Conforming clothing obj is gigantic! What gives?
Cyhiraeth opened this issue on May 10, 2004 ยท 6 posts
Cyhiraeth posted Mon, 10 May 2004 at 2:07 AM
I'm trying to make a conforming clothing item using Quick Conform, but when I click on the little shrugging guy to bring it up in Poser, the clothing item is gigantic! Like 5 times the size of my person. Any idea why it is doing that?
TrekkieGrrrl posted Mon, 10 May 2004 at 2:55 AM
Is it an obj you have made yourself? What happens if you import your obj? Does it fit then? The obj itself must be in the correct size.
Seraphira posted Mon, 10 May 2004 at 4:09 AM
hi, first thing is that you are dealing with max or something simlar you need to scale down the model... using object scaller 3c which is a freebie. you need to scale down 100. If you need some help I can help. :D I know how fustrating conforming figures can be. :D one question which program are you using to model the clothing? Seraphira
Cyhiraeth posted Mon, 10 May 2004 at 9:51 AM
Oops, sorry...I used Wings 3d to model it and if I import the obj, it appears to be of normal size. It's only when I use Quick Conform and then try to use the resultant cr2, that I get this gigantic obj.
TrekkieGrrrl posted Mon, 10 May 2004 at 1:04 PM
Now that sounds like a bug of some sort. So if you import your obj at 100% it has the correct size, but when it's conformed it grows? O.o
Cyhiraeth posted Mon, 10 May 2004 at 2:01 PM
It gets weirder....I imported it back to Wings to have a look at it, loaded the figure to compare size and lo, it was gigantic...so, I rescaled it and am starting from scratch.
