ssalter opened this issue on May 10, 2004 ยท 10 posts
ssalter posted Mon, 10 May 2004 at 9:23 AM
I tried searching through the forum for this but had no success. This may be possible but due to my serious lack of RTFM syndrome I don't know. Let's say I have a 'scene' with one character and I also have two or three pz3's of separate characters. I'd love to be able to 'import' an external pz3 into my current scene. I realize you couldn't really import an entire scene but it should be feasible to select a character and copy it into a new scene. Does this make sense? Am I dreamin'? I imagine it couldn't work with Poser 5 due to the way things are structured. But, it should be possible.
neilp posted Mon, 10 May 2004 at 9:33 AM
It is posible to import a whole scene into an existing scene. Go to File > Import and choose Poser file (pz3). Have fun.
ssalter posted Mon, 10 May 2004 at 9:39 AM
blush Now don't I feel abysmally stupid. hehe Thanks!
PhilC posted Mon, 10 May 2004 at 9:47 AM
If you save your existing characters to the figure library you'll have no trouble adding then to a new scene.
ssalter posted Mon, 10 May 2004 at 9:50 AM
Hi Phil! I've heard of that but haven't done it. hmm, I would do a save and navigate to my runtime/libraries/character folder?
PhilC posted Mon, 10 May 2004 at 9:54 AM
No you would use the "+" at the foot of the library window just under the text "Add to Library". This text is only visible when you have your mouse over the "+" and there is a figure in the scene.
EnglishBob posted Mon, 10 May 2004 at 9:55 AM
No, just select the figure and click on the + sign at the bottom of the library palette. If the character is clothed, you'll get the option to save as a complete set or nekkid body only. :)
EnglishBob posted Mon, 10 May 2004 at 9:58 AM
My insurance will cover the damage Phil. :)
PhilC posted Mon, 10 May 2004 at 10:02 AM
maclean posted Mon, 10 May 2004 at 2:20 PM
Actually, 3d max has this function (and it's intelligently implemented). It's called 'Merge' and not only can you merge scenes, but you can choose the exact items you want to merge from a dialog box listing the entire scene. I use it all the time. I've even programmed my own hotkey for it. mac
