grid opened this issue on May 15, 2004 ยท 21 posts
grid posted Sat, 15 May 2004 at 3:34 PM
TrekkieGrrrl posted Sat, 15 May 2004 at 3:39 PM
Have you grouped it? And could those odd polygons somehow belong to another group (or material zone)? Looks very odd indeed.
grid posted Sat, 15 May 2004 at 3:46 PM
Yea its Been Grouped To all the Right Groups. I even did it @ times to be safe... =( I will post the Group part to show
grid posted Sat, 15 May 2004 at 3:49 PM
nerd posted Sat, 15 May 2004 at 4:29 PM Forum Moderator
You're going to need to re-do the UV mapping on this. The UV co-ords in that spot are messed up. Load it up in UV mapper, you'll probably find those facets off in one corner or something. Nerd
grid posted Sat, 15 May 2004 at 8:54 PM
I have Redone the Uv maps as well..
grid posted Sat, 15 May 2004 at 9:05 PM
Its The Same Thing on Both Sides Of the Item.. I Redid The Uvs and I still get the same thing I regropup It over and over
nruddock posted Sat, 15 May 2004 at 9:22 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1703140
If the item has double sided polygons and your using P5, then you need to add a tiny displacement to each material, and set the displacement bounds appropriately (see linked thread).grid posted Sat, 15 May 2004 at 9:40 PM
OK THis is Whats Seems To be Going on. I Used UV Maper To Split The Shirt Front and Back. And This seems To Be causeing this. I i Dont use the Split by oritan and Keep it all together I dont get the mis place poly. This is strange. This Seems to happen With ever thing I made So far I just Check some other Iteams. Wounder why? sorry its p4
grid posted Sat, 15 May 2004 at 9:41 PM
nerd posted Sat, 15 May 2004 at 10:06 PM Forum Moderator
nerd posted Sat, 15 May 2004 at 10:11 PM Forum Moderator
nerd posted Sat, 15 May 2004 at 10:12 PM Forum Moderator
nerd posted Sat, 15 May 2004 at 10:15 PM Forum Moderator
nerd posted Sat, 15 May 2004 at 10:17 PM Forum Moderator
nerd posted Sat, 15 May 2004 at 10:19 PM Forum Moderator
nerd posted Sat, 15 May 2004 at 10:26 PM Forum Moderator
TrekkieGrrrl posted Sun, 16 May 2004 at 4:58 AM
Oh I would wish someone would do an easy-to-understand tutorial of the offset thingies in UVMapper (pro) I've simply never understood how they work. And being a total math-illiterate I always have to try them all to figure out which axis is x and which is z. The Y is USUALLY easy (from the top) but as soon as bu original ovj isn't facing straight ahead I'm lost. Help?
nerd posted Sun, 16 May 2004 at 6:10 AM Forum Moderator
Yeah and Poser's world being twisted 90 on the X axis doesn't help either. And don't feel bad I'm a math brain and I have to try them all first too. Nerd
grid posted Sun, 16 May 2004 at 7:45 AM
Yuper this is good stuff.... thx for the help.. its good to go now
Cyhiraeth posted Mon, 17 May 2004 at 4:09 PM
This is great, Nerd! This will help nicely with something I am texturing right now. Any chance you could do some more tutorials regarding this type of stuff? (pwetty pwease?) ;-)
