SteveJax opened this issue on May 16, 2004 ยท 12 posts
SteveJax posted Sun, 16 May 2004 at 9:58 PM
Attached Link: http://people.delphiforums.com/JAXOMSTEVE/Photo/Eli-n-John.jpg
Is it possible to fix an image like this old one of my grand father with the glare in Photoshop 7? If so, how do I go about doing it?retrocity posted Sun, 16 May 2004 at 10:38 PM
make a duplicate layer and adjust the LEVELS (Ctrl+L) then change the "blend mode" to Darken. Erase the right side of this layer to allow the underlying layer to show through.
Make another duplicate of the Background Layer and this time adjust the CURVES (Ctrl+M) Erase part of the right side again and set this "blend mode" to Hard Light.
Duplicate the original Background layer again and set this "blend mode" to Soft Light...
hope it points you in the right direction...
retrocity
SteveJax posted Sun, 16 May 2004 at 11:49 PM
Wow! That's pretty good for Quick! I'm a Photoshop newbie though, where do I change the blend mode? Next question... Can the child's face be sharpened up any? LOL Not sure which uncle that is.
Message edited on: 05/16/2004 23:57
retrocity posted Mon, 17 May 2004 at 12:14 AM
play around with the sharpen and sharpen edges filter (in the filters menu) to see if you can pull more of the child's features...
hope this helps,
retrocity
SteveJax posted Mon, 17 May 2004 at 12:17 AM
Grrr... Runnin' into lines where I cut here. This is gonna take some time. LOL!
retrocity posted Mon, 17 May 2004 at 12:29 AM
retrocity
SteveJax posted Mon, 17 May 2004 at 12:35 AM
Aaahhhhh...I used CUT LOL! Just cutting out a whole square. Time to start afresh
retrocity posted Mon, 17 May 2004 at 12:39 AM
aaaah... i've done worse!! :) retrocity
SteveJax posted Mon, 17 May 2004 at 12:48 AM
LOL Well when you said erase the dark half I just used the selection tool and selected the dark half then hit Edit/Cut. LOL Straight line down the middle of the image. Total Photoshop Newbie here. I'm surprised I figured out how to copy layers on my own.
retrocity posted Mon, 17 May 2004 at 1:03 AM
With constant software upgrades, the only difference between a "newbie" and an "expert" is six months ;)
i know there'll be some things in CS that i'll have to learn when i upgrade (i'm holding out for the company to pay first ;) )
any questions, just pop in and ask... we're always open 24-7 (sometimes in a row!)
retrocity
karosnikov posted Mon, 17 May 2004 at 5:49 PM
might want to add and subtract to the selection....and thn feather it... lets do a tute'
Boxx posted Fri, 21 May 2004 at 8:36 AM
One good trick to control good contrast on B/W shots is to covert to Lab color, select the Lightness channel, then convert to Grayscale. Ignore the other channels. Once in grayscale, duplicate the layer and set to multiply. From there you can adjust the top layer opacity. If you want to filter out set areas, create two versions, one normalising the overexposed areas, ond one normal one and history brush between the two.
