Subject: Championship Belt.....:O
galactron22 opened this issue on May 17, 2004 ยท 8 posts
galactron22 posted Mon, 17 May 2004 at 3:20 PM
I need a wrestling/boxing type championship belt. I know there is one for sale but in the MP but, I don't see the point of charging less than $10.00 to my visa. Does anybody know where I can find one for free?
your help will be appreciated.
Message edited on: 05/17/2004 15:21
Ask me a question, and I'll give you an answer.
pakled posted Mon, 17 May 2004 at 4:13 PM
how detailed do you need it?..;)
Big ol' Gold Belt..the precious metals that they have to smelt to make a ..;)
pakled posted Mon, 17 May 2004 at 4:28 PM
*-Dread Zepplin* 10 minute's work in Wings..may have to stretch it a bit, but it's in .obj format..;) let me know if you can use it..
galactron22 posted Mon, 17 May 2004 at 5:07 PM
It doesn't have to be extermely detailed, just you basic championship belt. this one looks good, but could you make the strap flat and wider with a buckle? OBJ is fine I can parent it in poser, and as far a s textures I can come up with something. Thanks, I appreciate it.
pizazz posted Mon, 17 May 2004 at 7:26 PM
One came in one of the first freak packages. I think it was a PC freebie. PRobably could be scaled down for Mike.
Marque posted Mon, 17 May 2004 at 9:37 PM
pakled how hard is wings to learn? Thanks, Marque
pakled posted Tue, 18 May 2004 at 11:53 AM
Attached Link: http://www.wings3d.com
Hm..Wings is probably one of the easiest modeling packages to use, once you have the interface figured out.. your right mouse button brings up the menus, the left makes selections. There's tons of tutorials in the Tutorials section here, and at the Wings site. There's a pdf manual as well on the site. For this, I created a torus, flattened the top and bottom (hardest part was getting the thickness right..;), scaled the middle front on the y axis, then extruded the faces of the belt a bit. The circle in the center was just a cylinder, inset slightly, and extruded inward. I haven't watched wrestling for years, so I've only seen people either waving or wearing the belt; I'm not sure what the buckle would look like. The modeling would be different if you were waving vs wearing(where noone sees the buckle..;) I can send you the obj, through email if you'd like. Wings is free, and once you smooth the rest of the belt, it probably starts looking more realistic..I have a lot of fun with Wings..and despite contstant downloading, usually wind up making my own props and clothes (well, hats..;) I'll pull it up and see what changes I can make..
Marque posted Tue, 18 May 2004 at 12:06 PM
Thanks! Marque
