TIMMYLYNN opened this issue on May 20, 2004 ยท 4 posts
TIMMYLYNN posted Thu, 20 May 2004 at 10:31 PM
Hi, I am trying to export a body part as an obj file and when i go through all the steps it looks like it saving the file but then all my options in the control bar are greyed out and I have to X out of poser. At that point it asked if I want to save the scene. I answered no and then I check for my obj file and it is not there. I have done this before with no problem. Any ideas as to why I can't get it to work now. It is like Poser does not want to export an OBJ file. I do have a camera parented to another camera. Would that cause this not to work? Any suggestions greatly appreciated. Thanks, TIMMYLYNN
AntoniaTiger posted Fri, 21 May 2004 at 12:48 AM
There's a known bug in Poser 5 running under some versions of Windows, which can be worked around by switching focus from Poser to some other program, and then back. It would be a big help though if you told us which version of Poser, and which operating system, as Poser 5 made a lot of UI changes, and many of the options are in different places.
SAMS3D posted Fri, 21 May 2004 at 5:55 AM
As Antonia said, we should know what versions you are using. Sometimes this would happen in my older version of Windows and all I had to do was when that box comes up, I would double click the clock on the taskbar, then close the clock box and all my boxes were no longer greyed out. Sharen
TIMMYLYNN posted Fri, 21 May 2004 at 4:53 PM
Sorry guys. Poser 5 with latest sr and windows xp.
