tomasball opened this issue on May 25, 2004 ยท 16 posts
tomasball posted Tue, 25 May 2004 at 12:27 PM
I keep having problems downloading files from the freestuff area. I often get messages that the file downloaded is corrupt or empty. I think I started noticing this when I upgraded to Windows XP home edition. Does this sound familiar to anyone?
Tyger_purr posted Tue, 25 May 2004 at 12:36 PM
I have XP home. I have only found a few corrupt files, usually only when i am trying to download a bunch at once. thus far most have been "fixed" by redownloading them. maybe try downloading them again.
My Homepage - Free stuff and Galleries
tomasball posted Tue, 25 May 2004 at 12:38 PM
Doesn't seem to help. I tried downloading usslopez's "Tommy" character many times just to see if it was a fluke, and I never could get it.
Tyger_purr posted Tue, 25 May 2004 at 12:51 PM
I just downloaded tommy and opened it. so i dont think it is the zip file on their end. are you using xp's internal zip or something like winzip? whats your connection like? dial up or highspeed?
tomasball posted Tue, 25 May 2004 at 12:54 PM
I'm using the internal zip, at dialup. Most of the time I can't get anything that I can even try to unzip.
Tyger_purr posted Tue, 25 May 2004 at 1:01 PM
ya might try winzip (if you can download it). beyond that i'm not sure.
SoonerTW posted Tue, 25 May 2004 at 1:10 PM
you might give Winrar a shot too. I use it exclusively with windows XP pro.
ockham posted Tue, 25 May 2004 at 1:13 PM
Another vote for WinRAR (rarsoft.com). It's more powerful than WinZIP, and works very nicely with XP home.
Tyger_purr posted Tue, 25 May 2004 at 1:18 PM
I kinda dont like promoting a product over a solution, but i use XP home with internal zip over a dial up and I very rarely get corrupted files and when i do i redownload them and they work. Sorry.
pakled posted Tue, 25 May 2004 at 3:54 PM
or stuffit, or ultimate zip, or you name it..I've used Winzip since pkzip alpha v.097 (mid-80's..;), but winrar or stuffit will do zips and rar's, or the Mac stuff, which can be handy since a lot of the time, the files are interchangeable..
wrpspeed posted Tue, 25 May 2004 at 4:41 PM
i get that when i try to download a bunch at once (and also view pages). one thing to try is to reboot the computer before deleting the corrupt downloads. i did this once and some of them opened up.
SoonerTW posted Tue, 25 May 2004 at 7:32 PM
Hmm it sounds to me like a dirty line corrupting your packets. You might try reinstalling the modem and related software, if that doesn't fix it you can try replacing the modem. If that is not the solution that your local telephone provider should be brought in to test the line.
TrekkieGrrrl posted Wed, 26 May 2004 at 3:39 AM
You could also get GetRight or some other download manager (I know it won't work on Rosity's Download" buttons, but for many other things GetRight is a great help.
JohnRender posted Wed, 26 May 2004 at 10:00 AM
Windows' built-in support for zip files is not the best. It commonly gives the error that the file is "corrupt" (when it's not). Your best solution is to go download WinZip (it's free), install it, and let Winzip handle zip files. Remember, if the files were really corrupt, there would be a lot more complaints. Or, you could replace the TCP/IP packeting software that you use to connect to the DNS router along the ISDN circulatory ambiotic connector. Then, re-route power to the ODN circuits and reset your DSN and IP transport connectors. :-) In other words, look for the simpliest solution first (get Winzip) before doing something very complicated (like replacing a modem or motherboard).
pakled posted Wed, 26 May 2004 at 10:30 AM
oh..tried that, but the firewall won't let me have access permissions, either to the router or the proxy server..;) I've asked for the updated IP protocol..but so many packages don't seem to support it..and I keep crawling down ODN conduits in an attempt to run into 7 of 9, or B'ehlanna..but no luck yet..;)
tomasball posted Wed, 26 May 2004 at 11:58 AM
Whoo-hoo! I solved the problem by installing Winzip. Thanks for the input!
