Forum: Carrara
Subject: Depth of field?
notefinger opened this issue on May 27, 2004 ยท 5 posts
notefinger posted Thu, 27 May 2004 at 10:14 AM
Can you set up your camera so a depth of field effect is happening? I was noteing one of the Carrara renderings of a donut and a cup of coffie that had a nice change of focus as the objects recieded.
Hoofdcommissaris posted Thu, 27 May 2004 at 10:24 AM
Yes. Activate 'camera', click the 'Effects' tab. DOF is in there... (I am talking C3 here). Otherwise, the method I prefer, is to render as a .psd file and let Carrara render a 'Distance' channel. You can use that in postprocessing to make a DOF effect. You will have more control that way, and you have to possiblity to first clean up your render and then blur some stuff.
Rokol posted Fri, 28 May 2004 at 11:45 AM
DOF is good for small renders, it gives up on the big stuff though! Hoofcommissaris do you know of any tutorials for postprocess of blur effect? I have known you can use the distance channel etc. Just never quite knew how to apply it, I'm not very aquainted with all the ins & outs of Photoshop. Any help appreciated!! Regards Rokol.
rendererer posted Sun, 30 May 2004 at 8:03 AM
Attached Link: http://www.3dxtract.com
I'm writing a tutorial on this for 3DXtract at this very moment. Hopefully it will get published in a future issue.
Rokol posted Sun, 30 May 2004 at 9:07 AM
Fantastic! I will be looking out for it! Rokol.
