Forum: Bryce
Subject: above and below
palagas opened this issue on May 27, 2004 ยท 9 posts
palagas posted Thu, 27 May 2004 at 1:56 PM
Here is a picture I just made in Bryce. Trying this above and below water thing. All suggestions welcome. I'm still new at this.Tell me what you think
Zhann posted Thu, 27 May 2004 at 2:30 PM
Are you using a terrain for the water? It looks to regular? You need something more fractal/irregular...
Bryce Forum Coordinator....
palagas posted Thu, 27 May 2004 at 2:36 PM
Yes I am Using a terrain for the water. I'M just playing around with the settings, I'll try adding more fractal in the terrain editor, maybe that will help. Thanks for the input.
Henged posted Thu, 27 May 2004 at 3:32 PM
Try to use water not as surface but as volume, to do this press on water icon and hold mouse button
bikermouse posted Thu, 27 May 2004 at 5:02 PM
No sign of refraction, diffusion of light below the water's surface, that play of lights from the water's surface(forget what they call that but there's a program that generates those that you can use as a gel in combination with a parallel light). Add a fish or two
you might check in the archives here. It was a hot topic about a year or so ago.
Keep at it you'll do fine if you can get past all the suggestions and develop your own style.
Message edited on: 05/27/2004 17:03
Zhann posted Thu, 27 May 2004 at 5:20 PM
Caustics, bikermouse...=) Some tuts that will help; URLS Underwater/ Over-underWater http://www.geocities.com/SoHo/Square/5391/oceantutorial.html=Making real oceanwaves http://www.renderosity.com/tut.ez?Printable=254 http://www.wolfiesden.com/flash/bryce/tut/adv-lighting2.html http://3dtoday.com/Tutorials/2001/Feb/BryceSurf/default.asp http://www.brycetech.com/tutor/bryce/underwater.html http://www.3dcafe.com/asp/tutorials/bryce/underwater/underwater.asp http://members.tripod.com/~JerryLS/tutorial1.htm http://lonestar.texas.net/~laewing/UnderwaterTutorial/underwater.html http://www.phazedance.com/3d/wavetutorial.html
bikermouse posted Thu, 27 May 2004 at 6:33 PM
Yes! I dunno why I fergetz dat! Thanks Zhann!
pakled posted Thu, 27 May 2004 at 7:20 PM
thanks, Zhann..
TheBryster posted Thu, 27 May 2004 at 9:29 PM Forum Moderator
Here's a concept that works! Like this idea!
