Forum: Carrara
Subject: Just got C3...Lighting question...
madriver opened this issue on May 27, 2004 ยท 6 posts
madriver posted Thu, 27 May 2004 at 4:17 PM
I find this a pretty sophisticated program but I can't figure out how to see the lights interacting on a model in the assemble room. I've set preferences to Open GL but no go. Painfully difficult to see what your lights are doing without wasting time rendering an image.
goofball posted Thu, 27 May 2004 at 4:49 PM
Try going into your display properties and setting the lighting mode to actual. It will give you a rough representation of what is happening.
Kixum posted Thu, 27 May 2004 at 8:55 PM
You can also use the render preview tool to see what your final render will actually look like. -Kix
-Kix
madriver posted Sat, 29 May 2004 at 5:15 PM
I can't for the life of me find the display properties setting you mention goofball. Where is that located?
goofball posted Sat, 29 May 2004 at 6:15 PM
On the right-hand side of your screen, there are a few circle icons, the top one has an arrow pointing up, if you click on that it will take you to those properties. I can't post a screen now but I will a little later.
madriver posted Sun, 30 May 2004 at 1:27 PM
Found it! thanks!
