Subject: Why Flickering Shadows in AVIs?
moushie opened this issue on May 28, 2004 ยท 5 posts
moushie posted Fri, 28 May 2004 at 12:40 AM
Is there any way to avoid flickering shadows in AVI renderings?
TrekkieGrrrl posted Fri, 28 May 2004 at 4:13 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1796667
A little longer down this page there's a similar question. Perhaps it's the same issue?
xantor posted Fri, 28 May 2004 at 9:32 AM
The lights might be animated, sometimes the lights can be moved when animating the scene and that can cause flicker. Switch off the animating for the lights if it is not needed in the scene.
moushie posted Fri, 28 May 2004 at 11:55 AM
Xantor: That's it! Switching off animation eliminates the flicker. I've no idea why, but thank you very much. Incidentally, increasing map size as suggested in the link above provided by ernyoka1, does not prevent flicker.
xantor posted Fri, 28 May 2004 at 3:42 PM
It is a problem I had when I first used poser, eventually I worked it out by myself.
