yayasangel opened this issue on Jun 05, 2004 ยท 4 posts
yayasangel posted Sat, 05 June 2004 at 12:51 PM
i recently downloaded daz studio...and i was trying to work thru the tuts....but when it said add hair...i had no hair to add...whenit said click on part of the body u want to pose..i clicked nothing happen...any clues...thanks in advance
Pol posted Sat, 05 June 2004 at 6:27 PM
First you need to have ' things ' in the Content = Figures, Faces, Poses, Hair, clothes etc... So you have to buy from Daz those 'things'. Or you can download the Egyptian Scene which is already full of 'things' and free. Good luck
Shoshanna posted Mon, 07 June 2004 at 9:30 PM
Hi yayasangel, If you installed DAZ|Studio after installing Poser, you should have received an option to search for all installations of Poser on your hard drives. If you point D|S at your runtime folder, you should be able to access your existing Poser stuff and use it in D|S. It may not all work correctly as this is a beta program. If you search Freestuff you will find a section called Hair Objects in the Poser section. You might have some success with those. Just make sure you are downloading an actual hair model and not a) A texture set for one b) An add on pack for one. Instead of clicking on a body part, I would suggest you scroll through the drop down list of body parts and select the one you want from there. I haven't had any success with clicking on body parts in the preview window myself. Hope that is of some help, Shanna :-)
yayasangel posted Tue, 08 June 2004 at 12:06 AM
thanks gonna try that....
