Djeser opened this issue on Jun 06, 2004 ยท 4 posts
Djeser posted Sun, 06 June 2004 at 4:56 AM
I use P4, and PBooost to keep my folders straightened out. I have separate folders where I keep Freak and She-Freak stuff, both in figures and poses. In order to morph either figure, do I need to ensure they are co-located with the M3/V3 morph injection files? And do I also need to do that if I am trying to use Wyrmmaster's injection stuff for them? I'm getting "can't find...." for some injection morphs when I try. Thanks in advance!
compiler posted Sun, 06 June 2004 at 12:45 PM
The figures and INJ/REM poses can be in any folder you like. The folder that MUST stay where it was initially is the !DAZ folder, with all the subfolders (SheFreak, Victoria 3...). This folder is directly under the libraries folder in your Runtime, and must stay there for the INJ/REM poses to work. Hope this helps.
Djeser posted Sun, 06 June 2004 at 12:50 PM
Thanks for responding, compiler. I haven't touched the !DAZ folder; it's where it initially put itself when I first got V3, and then M3 and S3. In my Poses library, with PBooost, I have a V3 folder with all the morph injectors for V3, an M3 folder with all the morph injectors for M3, a SP3 with all morph injectors for her. I guess what I'm asking is if I should use the V3 morph injectors for the She-Freak, and should I move the Wyrmmaster She-Freak injection things into the V3 folder too? (Hoping I'm making sense!!)
Strixowl posted Sun, 06 June 2004 at 1:30 PM
I use PPP and PBooost. I have a Bank for each Character called M3 (v3,S3, SheFreak,Freak)Morph Inj with the appropriate morph injection folders/files in the Bank. Nothing else goes in this bank. Other morph sets such as Wyrmmasters,I put in a seperate Bank called for example "V3 BodyMorphs." This is where I keep Sara Spriteling, Veronica Vixxxen,VoluptuousVickie etc.etc. In the case of Wyrmaster's,Mil Deformer Set I gave it a new Bank "MilDeformers" containing "only" Mil deformer folders/files. This system has always has worked fine for me. :-) You asked: "In order to morph either figure, do I need to ensure they are co-located with the M3/V3 morph injection files?" IF, I'm understanding the above question correctly Id say no.
