Subject: RSR to PNG converter?
Francemi opened this issue on Jun 06, 2004 ยท 9 posts
Francemi posted Sun, 06 June 2004 at 7:04 AM
I found a free RSR to PICT converter (don't remember where) but I'd like to know if a RSR to PNG converter exist and if so, where can I get it? ;o) Thanks. France
France, Proud Owner of
KCTC Freebies
Fatale posted Sun, 06 June 2004 at 7:20 AM
Attached Link: http://www.dataweb.net/~harper/downloads/RSRConverter.zip
It's in the freebie section here :) I personally use it alot.
Francemi posted Sun, 06 June 2004 at 7:35 AM
Yes but that is the RSR to PICT converter. What I need is a RSR to PNG converter ;o( France
KCTC Freebies
Fatale posted Sun, 06 June 2004 at 7:44 AM
Attached Link: http://www.senosoft.com/softp3doDownload.php
oops
spedler posted Sun, 06 June 2004 at 7:44 AM
P3d0 Explorer can do png to rsr and rsr to png (here in the freestuff). Steve
Steve
Francemi posted Sun, 06 June 2004 at 7:52 AM
Thanks. I have P3d0 Explorer but is there a way to actually SEE the RSR? It shows the picture for the cr2 whether there is a rsr or a png. France
KCTC Freebies
spedler posted Sun, 06 June 2004 at 8:11 AM
If you select what P3d0 lists as a .cr2, then right-click and choose 'Edit image', a window opens with the title .rsr, not .cr2, and the thumbnail is displayed. I guess P3d0 is associating the .cr2 with its corresponding resource. You can then save the image as a png or an rsr (note that you may have to alter the extension manually).
Steve
Francemi posted Sun, 06 June 2004 at 8:18 AM
Ok thank you. It works fine. France
KCTC Freebies
AntoniaTiger posted Sun, 06 June 2004 at 9:06 AM
As I understand it, it's Poser 4 which needs an RSR file for the image. Poser 5 will read the RSR and generate its own PNG image. It's also possible to convert ordinary graphics to PNG, which can sometimes be a better way to make a PNG than using an in-Poser method.
