zarquen opened this issue on Jun 07, 2004 ยท 10 posts
zarquen posted Mon, 07 June 2004 at 3:04 PM
Hi. I need the following prop (I'm not english-spoken, so maybe my words ain't correct): the bubbles of foam that float over the water in the bath... Thanks in advance. PS: Truth is that I cannot say that in my home language, neither...
TrekkieGrrrl posted Mon, 07 June 2004 at 4:36 PM
I've made some morphing suds, they're here in free stuff. Perhaps you could use them? Eventhough they're really more like a blop of soap spilled on the floor. What is your home language? Perhaps someone can help you in your native tongue?
zarquen posted Mon, 07 June 2004 at 4:59 PM
Hi Thanks, I'm searching for it... Maybe I'll use some texture / morphs for RDNA MicroCosm. My home language is Spanish. Thanks
igohigh posted Mon, 07 June 2004 at 11:57 PM
This may sound odd but there used to be a freebie for putting hair on the P4Male's pelvis called HairBalls, I used them once for bath bubbles and for a bubbling witch's cauldrin by re-sizing the XYZ untill satisfied and grouping several together. And they didn't even clog the drain!!!
Casette posted Tue, 08 June 2004 at 12:04 AM
Hola zarquem
Dependiendo del efecto que quieras conseguir, hay en el MarketPlace varios props baratos que te pueden servir. Yo la verdad no he usado ninguno... les he echado un vistazo, pero ten en cuenta que aunque ronden los 6$ tan so, se tratan de prop ball con una transparencia... puede que te resulte m fil hacerlos tcon diferentes tamas, agruparlos, exportarlos como prop y duplicarlo varias veces
Si necesitas una espuma m compacta, la amiga TrekkieGrrrl (ernyoka1) tiene un freebie que te puede servir en su web, Morphing suds (tampoco lo he probado)
Esperando que sirva de ayuda, un saludo
Casette.-
CASETTE
igohigh posted Tue, 08 June 2004 at 12:06 AM
wyrwulf posted Tue, 08 June 2004 at 12:14 AM
Attached Link: http://www.philc.net
PhilC has a bubbles prop in his freestuff archive at philc.netzarquen posted Wed, 09 June 2004 at 3:38 PM
igohigh posted Wed, 09 June 2004 at 6:45 PM
P5? You might try looking at Ajax's thread about 2 weeks ago on Slime. With some variations it may work for a wet skin texture that can be wet up to her waist and dry above...?? Or you can try postworking it.
Casette posted Thu, 10 June 2004 at 2:28 AM
You can try to use this combination in Surface Material:
Object Color: Pure White
Highlight Color: Grey 50% (more near of white, more bright)
Ambient Color: Pure Black
Reflective Color: Pure White
Highlight Size: 50%
no more
This combination give a oiled-skin look, but its a beginning to obtain your wet skin
If you want wet skin textures in origin, Miss April for V3 by Morris have a very good look with thousands of little drops
CASETTE
