tomh21 opened this issue on Jun 08, 2004 ยท 6 posts
tomh21 posted Tue, 08 June 2004 at 8:37 PM
gebe posted Wed, 09 June 2004 at 2:40 AM
This only happens when your computer is out of memory.
agiel posted Wed, 09 June 2004 at 6:06 AM
That's correct. If you look at your scene..... 1501 objects and 8 millions of polygons could be enough to fill 2 G of memory. I have 1 G of memory on my machine and I start having problems around 2 millions polygons and 1000 objects.
spider1313 posted Wed, 09 June 2004 at 4:24 PM
And here I was thinking that I was unique with this little problem?!? The render I just posted here at the galleries http://www.renderosity.com/viewed.ez?galleryid=690170 was giving me exactly the same annoying little pop-up! I am running a P4/1.9Ghz/1GigRAM with almost 19Gig free space...the scene mentioned above weighed in at about 800 objects, 16 lights, approx. 150Mb in size, and well under 3 million poly's. I always hide and make layers invisible before rendering...except when I forget '-), and have rendered much larger files in the past...yet am still finding myself in this same situation! Any other thoughts on this matter would be greatly appreciated! ==steve==
dlk30341 posted Wed, 09 June 2004 at 5:41 PM
Yep....my last scene, it didn't make one bit of difference by hiding layers and rendering only visible.....I was only able to render in final mode..broadcast just crashed. I also was not able to save. Mine was only 12mil polys...the reason I say ONLY is because I've rendered at 24.9mil poly before with no problems. My last scene NO volumetrics and only 2 additional lights :O....The reason I found was I had too many Poser items imported. Too many trees & veg will also cause this to happen. My specs are 2g of ram & 59.9G of HD space available...so go figure.
spider1313 posted Wed, 09 June 2004 at 7:23 PM
Ya know, dlk30341...I, too, was thinking along the lines of the Posers, but then again...I have, in the past, had upwards of a dozen of 'em, including the third generations, so I'm not quite sure that this would be the problem here! Would love to go back in and check this idea out, but just don't have it in me to reconstruct this scene from the last "available" save '-)! And obviously in this latest render, the plantlife is certainly not the issue '-). Definitely gonna hang in and see if anyone else has anything to add here!
