Subject: Victoria 3 XprssnMagic - How Does It Work? & Where Is The PDF User Guide?
philjaeger opened this issue on Jun 12, 2004 ยท 6 posts
philjaeger posted Sat, 12 June 2004 at 2:22 PM
I downloaded Victoria 3 XprssnMagic this last week, so I take it that it is the latest version. I also installed Poser 5 v.4. If this program works intuitively, then I should be able to pick a facial expression, click "Copy to Clipboard", In Poser select Vicky 3's head, then click ctrl+v or Edit-> Paste I go through that routine, yet nothing happens. What don't I know? Also, is there supposed to be a pdf user file available? If so, I can't find it. Thank you, Phil Jaeger Studios
las_61 posted Sat, 12 June 2004 at 3:04 PM
did you inject the expression morphs into V3's head before pasting?
Fredy posted Sat, 12 June 2004 at 3:21 PM
I bought my version at DAZ and it has a PDF-documentation included...
bigtim posted Sat, 12 June 2004 at 5:38 PM
That's right - you first have to inject the expression morphs from the V3 head morph pack.
philjaeger posted Sun, 13 June 2004 at 2:46 PM
Thank you for your help, I still can't find the pdf instructions. I don't know why I would need them, but it would be nice to see what they look like. As for XprssnMagic, it works just fine now. I didn't realize that I had to the Pose menu & double-click the morphs to load them. I'm just getting used to v5.0.
philjaeger posted Mon, 14 June 2004 at 11:22 PM
I found the pdf instructions in Poser 5 -> ReadMe's -> ProductLists. I had to open the pdf directly. Initially, when I installed XprssnMagic, I was given a link to the guide, which didn't work.
