Forum: Carrara
Subject: HELP! Anyone get this message?
bluetone opened this issue on Jun 15, 2004 ยท 8 posts
bluetone posted Tue, 15 June 2004 at 9:33 AM
I hope someone has an answer as to why I'm getting THIS message whenever I try to go into the shader room. (See graphic) I also was getting it whenever I tried to open files or create a new file. Then I re-booted and re-started C, only to get this message again when going into the shader room. HELP!
Hoofdcommissaris posted Tue, 15 June 2004 at 9:36 AM
You are in Carrara 2 on a Mac? Then I had the same experience. I could only help it by upgrading. Otherwise go to the Yahoo Carrara list and maybe someone there can help!
falconperigot posted Tue, 15 June 2004 at 10:40 AM
Well yes, I have got this message many times and with no particular logic to it. I use Win98 and C3; after no problems, it just suddenly started happening. I suggest you do a clean install of C with the latest update.
micaelito posted Tue, 15 June 2004 at 12:22 PM
i had the same problem last month. I've re-installed my XP home and my c2 and it now works fine. Good luck !
bluetone posted Tue, 15 June 2004 at 12:47 PM
Sorry I forgot to mention. Win 98SE and C3 on a 1.4G Athalon with 512 RAM and 32M novia Graphics card. Thanx for the imput... guess I'll do the re-install thing... sigh...
mateo_sancarlos posted Tue, 15 June 2004 at 1:39 PM
If you get something like that in OS X, you can check for any hardware problems, and look for bad software that installs .kext files (like Norton). Repair permissions, run Diskwarrior.
mdesmarais posted Tue, 15 June 2004 at 2:22 PM
You should trash the prefs file too- before anything else. You never know! Markd
ShawnDriscoll posted Wed, 16 June 2004 at 12:16 AM
I get that error when I have a DCG plugin installed. I haven't isolated which one, though. www.shonner.com
