Subject: Morphs???
Mattek opened this issue on Oct 19, 2000 ยท 2 posts
Mattek posted Thu, 19 October 2000 at 10:55 AM
What is morphs and how do i use them. I feel I am missing out on a big part of poser...
tbsro posted Thu, 19 October 2000 at 11:21 AM
You can download a ton or morphs from http://morphs.bbay.com Morphs allow you to change the appearance of the people in Poser. You use them by double clicking the body part you want to change (for example, if you want to use a morph for the P4 female's lips, you would double click the head) then click add morph target. Then you find it on your hard drive (you should upzip them to your runtimegeometries directory in Poser, I put mine in a sub folder called Anatomy Morphs) and then double click the morph and it will add it. Click ok and you will see a new dial in the dials for that body part. Just turn the dial with the mouse and it will apply the morph. Most morphs work best when set to 1.000 but many can be used at larger or smaller settings for different effects. Hope this helps. Tara
