internetuser opened this issue on Jun 20, 2004 ยท 12 posts
internetuser posted Sun, 20 June 2004 at 7:56 AM
Newbie question: Sorry to bother you. I am applying a default brick material from category rocks. The problem is that it shows very small. I edit the material and change the picture scale to say X:1.5 and Y:1.5 but i cannot see that it has changed in the model.Am i doing something wrong or missing something? Thanks
gebe posted Sun, 20 June 2004 at 9:44 AM
Do it this way: In the small material window at top right of your Vue interface, scale the brick to something highter. Guitta
internetuser posted Sun, 20 June 2004 at 10:30 AM
i have put a greater value i.e 2 but that didnt work either. any other way please?
gebe posted Sun, 20 June 2004 at 2:14 PM
internetuser posted Sun, 20 June 2004 at 3:49 PM
The model has been imported into vue as a 3ds model. Maybe it plays a role the different format? Maybe 3ds cannot be textured as a native Vue file. I have also tried the cube example as you mentioned and it does work. The exported file comes from sketchup. Thanks
rds posted Sun, 20 June 2004 at 4:14 PM
One thing to try is to ungroup your SU import and then try and texture it. This may help. :O)
rds posted Sun, 20 June 2004 at 4:16 PM
Also if your model is not grouped from SU try splitting it in vue into its individual components. Then texture each componet. :O)
internetuser posted Sun, 20 June 2004 at 4:21 PM
rds posted Sun, 20 June 2004 at 4:34 PM
Looks like progress, try turning your bump down a bit? :O)
internetuser posted Mon, 21 June 2004 at 4:43 AM
So what does it go wrong on the material scale i posted above and it shows too many black dots. How do i improve it? how do i make it look like the picture posted by gebe?
gebe posted Mon, 21 June 2004 at 5:05 AM
If you want smoother bricks, click the material editor for it, click "bumps" and scale down the Bump gain.
internetuser posted Mon, 21 June 2004 at 10:24 AM
Thanks to all your help. It worked.
