TwistedBolt opened this issue on Jun 26, 2004 ยท 10 posts
TwistedBolt posted Sat, 26 June 2004 at 5:00 PM
I eat babies.
TwistedBolt posted Sat, 26 June 2004 at 5:02 PM
I eat babies.
TwistedBolt posted Sat, 26 June 2004 at 5:11 PM
technical stuff: 1.fingers will be posable 2.eyes are seperate,for real eye looking textures 3.mouth has actual seperation for improved look 4.A videogame un-unified mesh and joint system 5.improved body detail 6.original leg&waist area has been fixed(with new joint structure) 7.I will spend a long time on making the meshUV layout as close to the Mike1&2 UV layout,for easy texture stealing and useing 8.higher rez mesh....as can be seen. This will be the place holder before Bman 2 rolls out(hes taking some time to tweak...over 1 million polys,bman1.5 is still under 5thousand)
I eat babies.
TwistedBolt posted Sat, 26 June 2004 at 5:15 PM
hopefully I can get it done by the end of summer....but making the uv compatible will take the longest,the actual working model is nearly done(just needs to be parented together in bryce).
I eat babies.
vasquez posted Sat, 26 June 2004 at 5:24 PM
ghhh ghhh lurking and dribbling
TwistedBolt posted Sat, 26 June 2004 at 5:43 PM
the fingers set the joints up in the numbers though,lets pray daz adds a tree structure or something.Maybe giving diff group colors will help too.
I eat babies.
TwistedBolt posted Sun, 27 June 2004 at 3:05 AM
The Bman2 mesh is as of yet a single unified type....I may use the daz thing to my advantage to make it seamless,if that is what people want.I have even modeled in hinted veins in the mesh,near the arms,neck,pecs,choler(sp) bone.very detailed mesh,probably on par with mike 4 when it hits.Mine will be free though.
I eat babies.
Pol posted Sun, 27 June 2004 at 7:09 PM
I'm very interested. Your project sounds great almost like a dream. What do you mean by " the Daz thing "..?
TwistedBolt posted Sun, 27 June 2004 at 8:29 PM
"Daz Thing"= using poser4 pro and set up the figure in in poser(as a poser figure) and then use the compatability of DAZ bryce to my advantage.If bryceman 2 was a poser fig,it would be cool,but not everyone can use it then.
I eat babies.
Pol posted Sun, 27 June 2004 at 11:13 PM
Bad luck for me, I do not have Poser4 Pro nor Poser 5.
