Forum: Carrara
Subject: How to make a satin or silk shader?
Vidar opened this issue on Jun 29, 2004 ยท 7 posts
Vidar posted Tue, 29 June 2004 at 2:40 PM
if someone has a good tip for this then please let me know.i have an idea in my head for scene but i dont know how to make a silk or satin shader in carrara 3,i know how to paint it in zbrush or photoshop but i dont want to use textures. Thanks Dominik
falconperigot posted Tue, 29 June 2004 at 3:26 PM
This is a Multichannel Mixer using Brick as the Blender. I tiled the bricks 500 in each direction, 40 for the grout value and curves checked. Then each channel has slightly different color, highlight, shininess & reflectivity. Adding a bit of bump would probably help. And you need to watch the mapping mode. HTH Mark
Vidar posted Tue, 29 June 2004 at 4:31 PM
Thanks for the help Mark,i will check this out.:)
naniwa posted Tue, 29 June 2004 at 7:46 PM
Do you have "Shader ops" ? This plug-in is helpful to make a shader for the silk or satin.
Sachiko
bluetone posted Tue, 29 June 2004 at 7:57 PM
Can you give us a screen shot of your shader? I looks great!
naniwa posted Wed, 30 June 2004 at 12:41 AM
OK! Here it is. Neither of shader has bump.
Vidar posted Wed, 30 June 2004 at 12:44 AM
thanks and yes i have shader ops,great shader naniwa!!
