Subject: Problem importing Kyoko hair in 3d programs
duesentrieb opened this issue on Oct 26, 2000 ยท 12 posts
duesentrieb posted Thu, 26 October 2000 at 4:02 AM
I'm trying to import Kozaburo's Kyoko hair as a OBJ into Bryce and RDS, and the import and texture mapping works OK. The problem lies in the transparency. In both programs, the front hair part doesn't get transparent and shows up as a white mesh with the hair texture on it. The transparency map itself looks OK to me, but why doesn't it work? Am I doing something wrong? Please help me, because it's such a beautiful hairdo which I would miss very much!
bloodsong posted Thu, 26 October 2000 at 6:54 AM
heyas; you might need to invert the transparency map to get it to work in 3d progs other than poser. not sure about bryce... that uses typical alpha channels, right? i know ray dream uses 'white is transparent.' at any rate, the object/item in an alpha channel is usually black, while the 'transparen't bit is white. try it out.
picnic posted Thu, 26 October 2000 at 7:43 AM
You do have to more or less invert transmaps in Bryce (you can paste it to center area, then use the half blk/half white thing to get them right as I recall). Also, as I remember, the Kyoko hair was a bit more difficult because there are several .objs to consider--not just the one object. Scroll through the hair objects and see if I'm correct. There is a bang type thing that needs the transparency applied to it also--don't forget to add 'blend transparency' in the pull down menu beside the little 3window thingie on the right. You will need to make sure you have the transmap applied to each part of the hair and there are several parts. Way back in the archives in the Bryce forum, I did a show and tell with pics of the models and the material lab for the Kyoko hair--you'll see all the settings there. Look for picnic posts and look through them. Don't remember the thread title.
duesentrieb posted Thu, 26 October 2000 at 10:16 AM
Thanks picnic, your tip on activating the "blend transparency" option in Bryce did the job! Still, I can't get it working in RDS. Any suggestions for this one?
picnic posted Thu, 26 October 2000 at 10:54 AM
Don't I wish LOL--I don't have RDS--just wish I did G.
Marque posted Thu, 26 October 2000 at 12:17 PM
Where can I find the Kyoko hair please? Marque
Jaager posted Thu, 26 October 2000 at 1:00 PM
Poser Factory: http://www.interq.or.jp/red/pandt21/ is the gateway. There is a new hair model pending from Ryo , the particular hair you are after, may only be available as a part of one of the NeNe or LinLin characters. Anyway, the various hair props which are linked thru the above site, are excellent , state of the art , and have set the standard for all others.
Marque posted Thu, 26 October 2000 at 1:05 PM
Thanks luv, on my way! 8^) Marque
picnic posted Thu, 26 October 2000 at 2:34 PM
Do check out the hair on Linlin in the Japanese pages--you can see a 'demo' I did of that in a similar hair thread on 3D Commune.
Marque posted Thu, 26 October 2000 at 8:14 PM
Couldn't find the Kyoko hair....oh well. Marque
picnic posted Thu, 26 October 2000 at 8:58 PM
Marque, they've just redone their pages it seems. Go to this page http://www.lvn.co.jp/poser/DLMainFrame.htm and click on MT Characters. You will get a page with a lot of their poser folks. Scroll down to Nene 4.1.1SE. She comes with the Kyoko hair.
Marque posted Thu, 26 October 2000 at 9:29 PM
Oh thank you! Marque
