bazze opened this issue on Jul 09, 2004 ยท 7 posts
bazze posted Fri, 09 July 2004 at 6:19 AM
Attached Link: http://www.colacola.se/howto_1.asp?pic=2801
The space background maker set!!The set is a pds-file (Photoshop & Paintshop) with a number of different layers specified below.
The psd-file contains 3 high res layers (beside the info layer that you can turn off).
One layer with a star field.
One layer with a huge planet.
One layer with an asteroid field.
You can move, dublicate, resize, rotate, change the colors on each layer or whatever you like and come up with your own space background. The examples below are created with just a couple of clicks. Example1:
Example2:
I got this idea when I was archiving this old image of mine:
I basically removed the space ship, optimized, organized and merged a couple of layers making it usable for others to use. Download it from here: http://www.colacola.se/howto_1.asp?pic=2801 Hope you can use it!
www.colacola.se
