fls13 opened this issue on Jul 11, 2004 ยท 8 posts
fls13 posted Sun, 11 July 2004 at 10:45 AM
kuroyume0161 posted Sun, 11 July 2004 at 11:28 AM
For one thing, as far as I know, connecting the texture into Specular_Color whilst set to 'absolute' black (i.e.: 0/0/0) will have no effect whatsoever. Absolute black in the specular color channel is equivalent to 'OFF'. The contrast may be a result of using a color map as a bump map. Certainly looks that way in the material surface view.
off.
-- Bjarne
Stroustrup
fls13 posted Sun, 11 July 2004 at 11:47 AM
I'll give it a whirl and hope it works. Thanks.
ronstuff posted Sun, 11 July 2004 at 12:10 PM
As mentioned above, the connections to Specular_Color and Specular_Value are doing nothing. The contrast is due to plugging the texture into the Diffuse_Value channel. What this tells Poser to do is "Make light things on the map lighter and make dark things on the map darker". There are much better ways than this to bring more contrast to your map and provide more control - such as using a bit of Gain between the map and the Diffuse_Color channel. The extra "detail" you are noticing is due to the bump map - adding a bump map to most textures will increase the detail and make the skin look more realistic.
fls13 posted Sun, 11 July 2004 at 12:24 PM
Gain? Where's that?
AntoniaTiger posted Sun, 11 July 2004 at 12:28 PM
Trouble is, just using the normal texture as a bump map can do odd things. It's the greyscale value that decides how high a bump is -- now imagine what will happen if you use a texture map for a character who didn't take off their swinsuit to get an all-over tan.
iamonk posted Sun, 11 July 2004 at 1:30 PM
Here's a little trick for the bump... I found it in a thread recently, I'd love to give credit, but I don't remember who or where it came from. ...create a math node at your bump, use subtract, and subtract your texture from 1.
iamonk posted Sun, 11 July 2004 at 1:52 PM
