MINTY1974 opened this issue on Jul 15, 2004 ยท 5 posts
MINTY1974 posted Thu, 15 July 2004 at 11:56 PM
lundqvist posted Fri, 16 July 2004 at 2:20 AM Online Now!
Easiest way: Open all 3 three documents at once, select the "move" tool, click on one of the documents and drag onto another open one. PS will add a new layer with the content of the document you dragged from. In short, PS allows you to drag and drop between document windows. Alternatively you could select a source document, do edit->select all, copy, click on the destination document and paste.
RHaseltine posted Fri, 16 July 2004 at 2:40 PM
Hold down shift as you drag to make sure that they images arrive lined up (shift-drag puts one image on top of the other if they are both the same size, or centres the new image in the document if they are different sizes)
retrocity posted Mon, 19 July 2004 at 7:35 PM
also change the "blend mode" on the upper layers to allow the underlying image to show through...
you can find the blen modes in the layer palette, by default it is set to NORMAL... do a search in the forum for "blend mode" ... well, here are a few that talk about it:
http://www.renderosity.com/messages.ez?Form.ShowMessage=1813741
http://www.renderosity.com/messages.ez?Form.ShowMessage=1317871
http://www.renderosity.com/messages.ez?Form.ShowMessage=713695
hope it helps,
retrocity
retrocity posted Tue, 20 July 2004 at 9:38 PM
first layer has a blend mode of "Soft Light"
the second layer has a blend mode of "Screen"
and the bottom layer is left as "Normal", as this layer won't impact any other pixels (there's nothing left under it ;))
you can also change the opacity and fill of your layers for additional effect.
hope this helps,
retrocity
