Francemi opened this issue on Jul 17, 2004 ยท 4 posts
Francemi posted Sat, 17 July 2004 at 7:40 AM
If I want to use a clothing item on a figure and that item is not made for that figure, I parent it instead of conform, right? In the case of a dress, to which body part should I parent it so that it follows the moves of the body? Thanks. France
France, Proud Owner of
KCTC Freebies
PhilC posted Sat, 17 July 2004 at 7:47 AM
If its a mini skirt or a bikini you can sometimes get away with parenting it to the hip or chest and selecting the "bend with Parent option". However when a clothing item covers more than three body parts then your only real option is to convert it to conforming clothing set up to match the new figure.
Edit: If you have Poser 5 you also have the option of using the Cloth Room.
Francemi posted Sat, 17 July 2004 at 7:57 AM
Thank you. France
KCTC Freebies
FyreSpiryt posted Sat, 17 July 2004 at 4:06 PM
If you're doing stills, you can pose the clothing around the figure so that any poke-through is on the side away from the camera (where it isn't seen).
