Subject: Hair Recoloring In PSP 8
beachnut opened this issue on Jul 17, 2004 ยท 4 posts
beachnut posted Sat, 17 July 2004 at 10:41 AM
I'm having trouble making a brunette color on hair. I'm able to do blondes, redheads and any others....I just can't seem to manage working the RGB settings to make brown/brunette. Could anyone share a tip or two? Thanks! :)
3-DArena posted Sat, 17 July 2004 at 11:00 AM
Let's see I used to try different methods to re-colour hair in psp7 should work in psp 8 (which I have and rearely use LOL). One is a layer over the hair flood filled with a colour and then set to "Hue" or "colour" The other is that I never used the "colorize" option makes hair look too flat I use the Hue/Saturation/Lightness instead.
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use.
-Galileo
Francemi posted Sat, 17 July 2004 at 2:05 PM
Try to adjust the gamma at a lower position. Then colorize. If you start with a light shade of hair, even if you colorize with the correct color for brunette, it will still be much too pale. France
France, Proud Owner of
KCTC Freebies
compiler posted Sat, 17 July 2004 at 2:26 PM
The reverse is true : I've ,ever been able to achieve a decent blonde colour when starting from a black hair tetxure.
