Forum: Bryce
Subject: generic faillure !!!!
DonCorleone opened this issue on Jul 18, 2004 ยท 10 posts
DonCorleone posted Sun, 18 July 2004 at 7:41 PM
not long time ago... i impotr an obp in bryce 5.... and when i delete it.... almost objects i had in my import objects... dissapear. But now.. when i try to import obp objects... it's mark generic faillure. Can i remedy to this whitout reinstall bryce 5. Because i have lot of stock to reinstall back... (sky... materials... ) Help please DonCorleone
TheBryster posted Sun, 18 July 2004 at 8:13 PM Forum Moderator
You could just un-install the corrupt obp directories, create new ones and re-install them, instead of a complete Bryce re-install.
Peggy_Walters posted Sun, 18 July 2004 at 8:36 PM
Attached Link: http://users.tns.net/~mwalter1/
Take a look in the directory and see if there is a *.tmp file. Delete it if it is there and try again. Check my site - I have empty object and material preset files for download. You can delete the ones that are broke and replace with the empty one. Hope you didn't loose anything important.
LVS - Where Learning is Fun!
TheBryster posted Sun, 18 July 2004 at 8:40 PM Forum Moderator
Nice one, Peggy!
DonCorleone posted Sun, 18 July 2004 at 10:09 PM
the problem is... i cant import no more objects in the directories..... it's just tell me.... An unexpected error has occured ( generic failure ) and where it was objects before.... there are white screens.....
Ang25 posted Sun, 18 July 2004 at 10:12 PM
This might be because you have imported too many obj for one directory. There seems to be a limit after which the files corrupt. Not sure if this is your problem. If it is do what Peggy suggests, also create your own directories for storing objs.
DonCorleone posted Sun, 18 July 2004 at 10:39 PM
Thank's for help...... Don.
TheBryster posted Mon, 19 July 2004 at 5:00 AM Forum Moderator
Don Corleone: Do what Peegy sez or we'll make you an offer you can't refuse..............;-)
Peggy_Walters posted Mon, 19 July 2004 at 7:44 AM
Are you opening the same file each time you have the generic failure? If so, it may be that the file has been corrupted. I also had a problem with a texture file having a file name over 32 characters long that caused Bryce to give a generic failure.
DonCorleone posted Mon, 19 July 2004 at 11:07 AM
I'm gone reinstall everything.......... take lot of time.................... Thank's for help.
