4dogday opened this issue on Jul 22, 2004 ยท 3 posts
4dogday posted Thu, 22 July 2004 at 11:30 AM
My CAMERA CONTROLS little dropdown arrow (For accessing your Camera angles)all of a sudden don't work. I'm Trying to use my Side View camera with it but the only way I can access the side view camera is with my CURRENT SELECTED ELEMENT. The Problem using that Camera is when I slide the figure over to the next position for alignment it looks like it is moved to the correct position. but when I test run it it is still walking in place. I have no problems when I work with the Camera Control dropdown menue. I also tried accessing it threw the Keystrokes, and throght the top menue with no luck. The CAMERA CONTROLS shows up, but the little arrow doesn't show up on my screen when I put my currser over that area to access it. any one know what put this problem into it's present state, and how to correct it? I hope it's not getting into Python Scriping, I never get into that area! One other thing, I CAN use the CAMERA CONTROLS to move objects around, I just can't access the different cameras. Thanks Brint
lesbentley posted Thu, 22 July 2004 at 4:19 PM
This can happen when the 'Camera Controles' have been moved too close to the top of the screen. You could try these things. 1. From the from menu bar 'Edit' menu, select 'General Preferences", then click 'OK'. 2. From the from menu bar 'Edit' menu, select 'General Preferences", then in 'Interface Preferences' select 'Launch to factory state".
4dogday posted Thu, 22 July 2004 at 5:31 PM
I didn't have my camera controls to close to the top, so I don't know what caused the problem, but as soon as I wrote the message I thought of the General Preferences and tried that. That cleared it up. I tried restarted my computer before I posted my message, sometimes that will unbug a problem. but that didn't work either. Thanks,lesbentley, I was under the gun, and I'm glad I got it fixed. Brint
