Subject: can you edit, cut down, clothing to make new clothing? for poser 5.
smitstop opened this issue on Jul 23, 2004 ยท 3 posts
smitstop posted Fri, 23 July 2004 at 10:43 PM
I just purchased Poser 5. I want to know if I can take a dress, for example and use the grouping tool to cut it into a different style?
and then can that be copied and saved as a new piece of clothing?
the poser 5 manual explains very little about anything, it assumes that I already understand 3-d and must also understand Poser.
can anyone help?
nomuse posted Sat, 24 July 2004 at 1:20 AM
Yes. :) There are multiple ways of going about this, with the grouping tool central and no other application needed. You could also simply make a transmap, or in some cases, just hide the groups that aren't needed. I'm not going to describe all of these methods in detail. Start with the manual. Use the tutorials available here. Use the search feature and read up on back-posts. You are going to need a certain base comfort with Poser before you go about altering clothes -- you should at least be able to import, export, and change textures around.
Message edited on: 07/24/2004 01:24
fls13 posted Sat, 24 July 2004 at 9:43 AM
The quick and easy way is to use transparency maps to shorten skirts, sleeves or coat lengths.
