Subject: Shadow issues
pbguy1211 opened this issue on Jul 23, 2004 ยท 8 posts
pbguy1211 posted Fri, 23 July 2004 at 11:39 PM
I'm having an issue with getting shadows to show up during rendering. I did a search and found a few things on it, but nothing concrete. Am I not doing something that I need to be doing in order to get a shadow to show up? It's visible in the pre-render stages, but once I render I get nothing. Any help is greatly appreciated. I'm using p5 if it matters. pb
TrekkieGrrrl posted Sat, 24 July 2004 at 3:35 AM
The "shadow" you see in a pre-render is not a shadow, its more like a placement guide. First of all, check that your characters and stuff in the scene is actually set to cast shadow, and also in the render settings, the Cast shadows must be ticked. Are you using raytraced or mapped shadows? Mapped shadows can sometimes dissapear if you have a large object in the scene (you can overcome this by choosing a larger shadowmap)
SamTherapy posted Sat, 24 July 2004 at 2:58 PM
Also, if your shadows are being cast on a ground plane or other prop used as a "ground", ensure that shadows are turned OFF for this object. At least, that's on a P4/PP render. It doesn't really affect Firefly as far as I can tell.
pbguy1211 posted Sat, 24 July 2004 at 6:08 PM
ensure shadows are turned off for which object? the "ground" itself?
SamTherapy posted Sat, 24 July 2004 at 6:39 PM
Yep, the ground.
pbguy1211 posted Sat, 24 July 2004 at 7:05 PM
okay... maybe i should try to make this a bit more clear. i'm trying to cast the shadow onto the ground. and nothing is working.
TrekkieGrrrl posted Sun, 25 July 2004 at 4:20 AM
Using firefly? Be sure to check Cast Shadows in the Render settings, if you're only rendering in draft mode I am not sure it's checked/ticked by default.
pbguy1211 posted Sun, 25 July 2004 at 10:47 AM
it is. i dont know why it doesnt work. but thanks for all the help anyway guys!
