dharmalion opened this issue on Oct 30, 2000 ยท 5 posts
dharmalion posted Mon, 30 October 2000 at 2:17 PM
Is there a correct/simple way to import a Poser character into Bryce and map the textures correctly? I am doing this: Export as Wavefront .OBJ = this works Import object in Bryce = this works It is gray, as it is supposed to be, but the character has 3 articles of clothing on, and it is REALLY laborious to select all the meshes of each body part to map the textrure. Does anyone follow me? Is there an easy way to do this?
CharlieBrown posted Mon, 30 October 2000 at 2:28 PM
Did you export as separate groups or as a single mesh? If as groups, you can select each item of clothing individually and USUALLY get the textures to apply correctly. It takes some playing, but I've gotten it to work about 80% of the time...
dharmalion posted Mon, 30 October 2000 at 2:33 PM
CharlieBrown: Do you mean exporting as seperate objects? If not, could you explain how you do this? Thanks in Advance.
CharlieBrown posted Mon, 30 October 2000 at 3:00 PM
When you export from Poser you have an option window that pops up including a bunch of options about the mesh. The last patch seems to have "stuck" these options on my screen, to a default that keeps each object as a separate group, but loses the group names (Group1-x is the "body" of the figure, 2-x is the hair, 3-x is clothing item one, etc.) It's confusing, but it works... ;-)
pendarian posted Mon, 30 October 2000 at 8:03 PM
There is an excellent tutorial on moving poser figures into bryce at this link: http://www.robinwood.com/PoserGoodies/PoserSet.html I suggest you go there and save that page or print it out, I did and it has saved me a lot of work :)
