Subject: Backgrounds
thefixer opened this issue on Jul 26, 2004 ยท 6 posts
thefixer posted Mon, 26 July 2004 at 12:23 PM
OK, I know this has been asked before but I can't find it so here goes.
How do I make my backgrounds fit my scene size rather than the scene size having to match the background.? I'm using P5 by the way if that makes a difference.
Thanks in advance of any replies.
Message edited on: 07/26/2004 12:26
Injustice will be avenged.
Cofiwch Dryweryn.
Francemi posted Mon, 26 July 2004 at 12:35 PM
If you mean import a background image you have on your disk, what I do is resize the image to fit the scene before importing it in Poser. France
France, Proud Owner of
KCTC Freebies
thefixer posted Mon, 26 July 2004 at 12:49 PM
Yea Francemi that's one way but apparently you can do something in the material room and that's the bit I need to know really. I've tried alls orts but can't get anywhere with it. The way you mentioned is certainly usefull but not ideal. Thanx!
Cofiwch Dryweryn.
markschum posted Mon, 26 July 2004 at 12:53 PM
I use one of two methods. 1. load a prop square to the scene. Resize and position it as the backdrop. In the material room set the image map as required. 2. get the Infinity Cove backdrop from runtimedna freestuff. You can try to scale the UV mapping in the material room.
neilp posted Mon, 26 July 2004 at 1:16 PM
The prblem here lies with the fact that your document window does not always agree to the render setting for the image size. Make both the same and it should be oK.
geep posted Mon, 26 July 2004 at 5:13 PM
Hi thefixer,
You can ...
CLICK HERE to hyperwarp to this tutorial.
You may find some answers. ;=]
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
