Methastopholis opened this issue on Jul 28, 2004 ยท 7 posts
Methastopholis posted Wed, 28 July 2004 at 6:00 AM
geep posted Wed, 28 July 2004 at 6:16 AM
Did you UNcheck the "Percent of figure size"? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
TrekkieGrrrl posted Wed, 28 July 2004 at 6:34 AM
It's caused by the 3DS being a newer version that the one Poser knows. Someone with a program like MAX may be able to fix it. It's not uncommon, unfortunately.
neilp posted Wed, 28 July 2004 at 6:52 AM
If you have a copy of MAX then you can choose to "attach" all of these objects together.
maxxxmodelz posted Wed, 28 July 2004 at 9:38 AM
The reason this is happening is because the model was saved as a 3ds with Xform modifiers. You need someone with 3dsMax to apply "RESET XFORM" from the tools panel on each part of the object that's "exploded", and resave. That will fix the problem.
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
hasseh posted Thu, 29 July 2004 at 12:34 AM
Message edited on: 07/29/2004 00:37
swfreeman posted Sat, 31 July 2004 at 8:33 AM
this happens often in max when you or the modeller mirror/ copy elements of the figure and use it somewhere else on the figurte again (wheels) .. its a nono for poser.
