Subject: i need a good text editor
superman32965 opened this issue on Jul 28, 2004 ยท 14 posts
superman32965 posted Wed, 28 July 2004 at 10:50 PM
i need a good text editor, to edit a obj. or cr2. if any one knows of one, i'd be greatfull for the 411.i'm not sure what kind of editor i need. please help.
nickedshield posted Wed, 28 July 2004 at 11:05 PM
Attached Link: http://www.EditPadPro.com
Here is a real good one, EditPad Pro.
mathman posted Thu, 29 July 2004 at 2:10 AM
Attached Link: http://www.notetab.com
Notetab Light. One of the best freewares around.
Lord_Lucan posted Thu, 29 July 2004 at 4:49 AM
Attached Link: http://www.liquidninja.com/metapad/
I use Metapad - haven't really used a lot of them, but I prefer it over Notepad.
Phantast posted Thu, 29 July 2004 at 5:11 AM
Attached Link: http://www.lancs.ac.uk/people/cpaap/pfe/
I like Programmer's File Editor (PFE). It's no longer under development, but I find it powerful and easy to use.
kuroyume0161 posted Thu, 29 July 2004 at 8:19 AM
Attached Link: http://www.ultraedit.com/index.php?name=Content&pa=showpage&pid=1
And, finally ;), there is UltraEdit32.
 -- Bjarne Stroustrup
Bobbie_Boucher posted Thu, 29 July 2004 at 9:14 AM
Attached Link: http://www.editpadpro.com/editpadlite.html
Edit Pad Lite is free, and handles everything I've tried. Why pay for a text editor when a free one will do the job nicely.
layingback posted Thu, 29 July 2004 at 10:12 AM
Attached Link: http://vim.sourceforge.net/
gVim, esp. if you add Dodger's Poser Syntax checker.
It's essentially Unix Vi but with a GUI so you don't have to learn every arcane command to use as a normal editor. But the full power of Vi is there - including scripting - whenever you need it. And FAST! It loads multi-MB files instantly.
And Dodger's Poser syntax script poser.vim) displays all Poser syntax color coded. And a similar feature for Python is built in.
Price is right too - $0.00.
Crescent posted Thu, 29 July 2004 at 9:16 PM
Attached Link: http://www.textpad.com/
I love Textpad, personally. It's only $16.50 and you can try before you buy. It has things like bookmarks and line numbers so it's really useful for me.
hogwarden posted Fri, 30 July 2004 at 7:32 AM
Attached Link: ZPad
Blimey! So many text editors! If you need one which can load and save *compressed* Poser content files, and has Poser Syntax highlighting and a feature to jump to a particular section of the file, you could look at Zpad? H:))
sixus1 posted Fri, 30 July 2004 at 9:18 AM
I just use notepad :)
Bobbie_Boucher posted Fri, 30 July 2004 at 9:28 AM
Notepad is very limited. It can't always handle the size of the files I want to use. Plus, Notepad doesn't like to use different file extensions. EditPad Lite will load anything you give it.
nickedshield posted Fri, 30 July 2004 at 10:31 AM
One thing editpadlite or pro cannot handle is compressed files. If you are doing a lot of compressed file editing the zpad probably is the best because it can read them.
hemi426 posted Sat, 31 July 2004 at 5:07 AM
Attached Link: http://www.meybohm.de/index.uk.html
I would vote for Proton
