Subject: Several Firefly Render Problems SOLVED!
ronstuff opened this issue on Jul 31, 2004 ยท 12 posts
ronstuff posted Sat, 31 July 2004 at 11:37 PM
Attached Link: Firefly Render problems solved
all at once, several problems which have plagued some Firefly renders since P5 was introduced are likely to be remedied by this simple solution. I discovered this while I was testing the specific problem of artifacts in refractions, reflections and shadows, and discovered that many problems may all be due to the same common source. You can read about it at this link. It is a long post, but if you are in a hurry, you can jump to Post #3 for the summary and then go back and read the full discussion if you are interested.
