Subject: Clogged up Libraries
momodot opened this issue on Aug 02, 2004 ยท 5 posts
momodot posted Mon, 02 August 2004 at 8:12 PM
My Libraries are clogged up... I have a folder in my MAT poses though that displays the name only without a thumbnail... how is this done? can it be turned on and of? It woulb be great if folder level had no thumbnail/icon for P5 but only the content in the subfolders...
Max_Raptor posted Tue, 03 August 2004 at 2:39 AM
Hi If I understand you right, I think we have the same issue. What I have seen is that POSER have a limmit of the number of files/thumb's in one folder. Once u have to many it will be just the file names, I made sub folder and moved some of the files in there, then it works.. why this is ? I have no clue
TrekkieGrrrl posted Tue, 03 August 2004 at 4:35 AM
In Poser 5 SR4 this is a known "bug" (actually it's claimed to be a feature) You need to open the LibraryPrefs.xml (in the Poser 5Runtimeprefs folder) and change the PreviewNum=100 to something larger. I set mine to 500. You can make a copy of the file first, just in case.
TrekkieGrrrl posted Tue, 03 August 2004 at 4:38 AM
Oh and Poser 5 has no technical limit of items in a folder, and apparently not even for number of nested folders (ynsaen made a test not so long ago which revealed that Windows gets into problems before Poser 5 does) In Poser 4 and Pro Pack however, you do have a limit or 256 folders in each category, and even before that, the names starts to get truncated, and at a point you will discover that you can no longer acces the lower potion of your folders (another reason for all the !!!MyStuff folder names...)
momodot posted Tue, 03 August 2004 at 9:01 AM
It is a feature! I was wondering how to set it... maybe to kick in at fifty or even twenty-five. Thanks!
