Subject: saving just a leg
iplooney opened this issue on Aug 06, 2004 ยท 6 posts
iplooney posted Fri, 06 August 2004 at 11:48 AM
Hi - newbie question. How can I save just a leg along with the texture in a poser file. Thanks in advance
markschum posted Fri, 06 August 2004 at 12:10 PM
When you save a figure you should get a 'select subset' button on the save dialog - click it and select the parts you want saved.
note: I do not think that poser will cap any body parts. That is you will have a hole at the top of the leg.
Message edited on: 08/06/2004 12:11
iplooney posted Fri, 06 August 2004 at 12:58 PM
Thanks - I tired the save but I can't see any sub-set options on the save dialogue.
Crescent posted Fri, 06 August 2004 at 1:09 PM
http://www.morphworld30.com/tutorials/limbs.html - Traveler's tutorial should work for you. Cheers!
SnowFox102 posted Fri, 06 August 2004 at 1:31 PM
It depends on what version of Poser you have. Only 4 and up can save single parts easily. 3 Requires you to "hide" all the parts that you don't want saved.
ronstuff posted Sat, 07 August 2004 at 1:04 PM
I don't think you can save parts of a figure by selecting a subset. You CAN use the grouping tool to spawn a prop of any or all body parts and then save that as a prop.
